gas tank removal
gas tank removal
Hey, guys. I'm doing what andym suggested in one of my previous threads. My fuel gauge in the front tank doesn't work, but the pump does and the rear tank's fuel pump don't work, but the fuel gauge does. So I'm dropping the rear tank to replace the fuel pump for now until I can afford to replace the sending unit. I took it to a mechanic because I'm so short on time, he quoted me a whopping $700! Needless to say, I'm doing it myself. Does anyone have any suggestions or tips or even a link to find some before I finish? I started pulling the tank last night, but I realized that the last bolt needs to soak with PB over night.
Bradley
Bradley
Okay, I'm in a snag and need some help. I've all but pulled the tank. The last thing is the fuel lines and from what I've read, they need a special tool. I've looked at advanced's site and there's more than one fuel line tool. I'm really stumped. Anyone else done this? I've seen pictures of tanks and mine looks really different.
Bradley
Bradley
Check out this article
How to Replace The Fuel Filter In Your Ford F-150
The process is the same on the pump as the filter
On my 96, you had to use two different sizes, but I don't remember what they are. Hopefully someone else will know.
I really appreciate it, but it turns out I only needed one and for once, it was the right one the first time. Bad news is I need a new fuel tank. I've heard from a friend that a 33-gallon bronco tank will fit? My tank is just too rusty to use anymore and since I have it out and it's cheap for a new one, I'd rather just have a new one.
Yes, I did this mod and like it very much. Don't forget that you will also need a pump and sending unit out of a Bronco as well. The Bronco tank is twice as deep.
https://www.ford-trucks.com/forums/7...ank-mod-3.html
SSellers
20
12-24-2013 12:47 AM
Ryan.J.M.
11-01-2012 06:31 AM
jackslater
07-11-2011 10:42 PM
