8mpg?! REALLY?
Old Feb 23, 2010 | 12:18 AM
NW 150's Avatar
NW 150
8mpg?! REALLY?
ive got a 96 f150/300 I6. i feel like its getting like 8-10mpg and to me there is no reason why it should be gettin that low of a number. heres the thing though, where are the gallons on the gauge for one of these trucks? cause i drive about 18-20 miles and the needle goes from the right of the F to almost the end of the first quarter of the tank!!! is there 6 gallons on E??? this is gettin aggravating because it seems like its gettin horrible mpg and it shouldnt be. help please!
Old Feb 23, 2010 | 12:23 AM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Ignore the gauge. The only way you can get an accurate estimate is from the amount of fuel it takes to refill the tank.
Old Feb 23, 2010 | 12:37 AM
TexasGuy001's Avatar
TexasGuy001
Agreed, you need to calculate your fuel economy. Just fill it up and use the trip set and see how many miles you go and then divide the amount of gallons used to fill back up into that number to see what your MPG is. Also if your speedometer has not been recalibrated for the larger tires it will read a bit slow and you odometer will read slightly less miles than actual.
Old Feb 23, 2010 | 08:09 AM
NW 150's Avatar
NW 150
yea i had a feeling that gauge isnt any good really. itll be on one of the quarter lines one moment then between two the next. and my tires change my mileage by .3, ill have to do the trip thing though. im hoping in that its all good and the gauge is just crap for reading
Old Feb 23, 2010 | 08:14 AM
darthice's Avatar
darthice
also make sure your PSOM is programed for your 32 in tires if it isnt i would say alot of your problems stem from that.
Old Feb 23, 2010 | 08:17 AM
Nealcrenshaw's Avatar
Nealcrenshaw
Also make sure you're using at least Plus, Regular will burn like water.
Old Feb 23, 2010 | 08:22 AM
darthice's Avatar
darthice
honestly on my 5.8l i have seen no change in mileage between using regular and plus gas
Old Feb 23, 2010 | 09:04 AM
pete17c's Avatar
pete17c
only if it has water in it .. which is not unheard of .. I try and stay away from the 'no-name' gas stations ..
you really only need plus or super if your engine pings (detonates) on the lower grade .. I've done some trials (with my car, not the truck) and MPG didn't change at all w/ different grades ..
To operate a properly tuned engine designed for 87 octane with 89 or 91 octane fuel will only increase the cost of operation. No additional power, fuel economy, or durability will result from the higher octaned fuel.
Fuel Octane Selection
Old Feb 23, 2010 | 09:29 AM
pete17c's Avatar
pete17c
I just write the current odometer reading on the back of the receipt .. it has the gallons pumped on the front .. then enter the info into a spreadsheet I set up and walla .. let's me track cost too .. and any 'trends' become obvious ..
Old Feb 23, 2010 | 11:39 AM
410's Avatar
410
if the truck is getting that bad on mpg start with the basics tuneup then oxy sensor use only quality parts like motorcraft or bwd they cost a little more but in the long run theyll save you money
Old Feb 23, 2010 | 11:53 AM
70torino429's Avatar
70torino429
Sounds like either the gauge is bad or the fuel float may have a crack in it.
I had a similar thing happen when my float was bad, i'd fill up and the gauge would go to Full as expected, drive a few miles and it'd be back near empty, course 50 miles later I was still driving so obviously not out of gas. Eventually it got worse to the point it would say I was empty right after I left the gas station, LOL. Pulled the tank and found the float had a huge crack down the side of it (cheap napa fuel pump). Seems like you may have something similar going on, but not sure.
As far as octane anything more than 87 or 89 is just spending more money for no gain, unless you've adjusted your timing to require it like some do. The Chilton's manual specifically says not to use 93 octane for some models/years actually.
Old Feb 23, 2010 | 12:39 PM
NW 150's Avatar
NW 150
yea i had gave it a tune up a few thousand miles ago, cleaned the fuel injectors with the real stuff not the $3 bottles, changed the o2 sensor between the two cats about this time last year. and also iave had the 420 code come up for the cat efficiency below threshold (bank 1), so maybe one of my cats are bad or my front two o2 sensors are bad? i do realize though that when i fill up when the gauge is just above the E, i can get about 14 gallons, im pretty sure that it is a 18-19 gallon tank? so that means like i said that there is about 4-5 left on E?
Old Feb 23, 2010 | 01:58 PM
BCHauler's Avatar
BCHauler
The "E","F", and hash marks in between have little if any reflection on what is in the tank in my experience. I always fill my tank and use the trip clock to monitor mileage. I get about 330km on the front tank and 630 on the back on average. When my rear tank shows empty I'll often still have a 100km left.
Old Feb 23, 2010 | 09:28 PM
'90-f150-302-5spd's Avatar
'90-f150-302-5spd
Well, from my experiance, the 300 shouldnt be getting much better than that (in town, maybe 13mpg hwy). After all, it was probably the worst out of all of them (maybe not the 351). Also you shouldnt put anything in but regular unless you have a high compression engine. The higher octane means LESS EXPLOSIVE, a common misconseption. The only time I put higher grade in is at certain gas stations as there gas makes my rigs ping. Usually I try to avoid these places though.
Just my 2cents
Old Feb 23, 2010 | 09:32 PM
Bayer-Z28's Avatar
Bayer-Z28
My back tank does that.. Front tank is accurate..
Try this: Fill up, then drive to 1/2 tank and measure the mileage.. Top the tank off, take that mileage and divide it by the # of gallons you put in. = mpg.. Mine gets around 12city and 23hw (@ 65-70)
