1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
08 - 09 Mirrors
Old 06-18-2009, 08:36 PM
1_BIGMOFO's Avatar
1_BIGMOFO
1_BIGMOFO is offline
08 - 09 Mirrors
I posted something a couple weeks ago about 08 - 09 mirrors because i was curious about how they fit / work. Some guys said something about switching somehting from the right to the left and vise versa.
I purchased them and they just came in!!!
Does anyone have the wiring diagram or anything else I may need to do the install? I just want to make sure my i's are dotted and t's are crossed before i rip my truck apart for the install.. I cant wait to get them installed!!!
Thank you in advanse,
Rob
Old 06-20-2009, 08:57 AM
1_BIGMOFO's Avatar
1_BIGMOFO
Anyone??????
Old 06-20-2009, 10:09 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,426 Likes on 2,110 Posts
I moved your post to Super Duty for a better response
Old 06-20-2009, 11:43 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Search the forum for the fix. It's somewhat involved and you'll really need to want to do it.
Basically the issue is when you want to adjust the mirror the left-right controls are reversed. When you push to move the mirror right it moves left and vice versa. You get used to it real quick but you might want to change it.
From what I've read that involves taking the mirror apart and will probably be easier to do before you install them.
You'll need to remove a tab on the part that touches the door and the the wiring is pretty straightforward especially if you already have the built in running & signal light in your existing mirrors. I cut the plug off my old mirror and spliced into the new mirror's harness. All the wire colors match. Pretty easy.
Old 06-20-2009, 11:51 AM
Neil_E.'s Avatar
Neil_E.
Neil_E. is offline
The 09 mirrors move correctly. I don't know if the the 09 mirrors have a wiring change compared to 08 or if the switch is different. Maybe you should do a rough hookup to test the direction of movement before you take them apart.
Old 06-20-2009, 01:00 PM
juneau76's Avatar
juneau76
juneau76 is offline
I hate sounding like a bonehead, but you have an '09 so I would expect them to act correctly on your truck. Do you know someone who retrofitted '09 mirrors on a Pre-'08 truck and had them operate correctly or are you referring to yours operating correctly?
Old 06-20-2009, 05:20 PM
Neil_E.'s Avatar
Neil_E.
Neil_E. is offline
I'm just saying that they are correct on the 09. So if the 09 mirrors are a diffferent part number than 08, perhaps they might work right on an earlier vehicle.
Do they normally move correctly on the 08 models? I thought the 08 model year had the problem mirrors and when those were installed on earlier vehicles, they worked backwards as well.
Perhaps someone can set us straight. Does the problem only occur when the new mirrors are installed in older vehicles?
Old 06-20-2009, 06:11 PM
spinella's Avatar
spinella
spinella is offline
yes. the problems occur when the new mirrors are installed on a older truck.
Old 06-20-2009, 09:38 PM
Monster-4's Avatar
Monster-4
Monster-4 is offline
Here's one link on the wiring.
https://www.ford-trucks.com/forums/1...-all-done.html
I thought I bookmarked the one about reversing the mirror but I can't seem to find it.
Edit: Found it.
https://www.ford-trucks.com/forums/7...correctly.html
Edit: Here's another link for mirror swap.
https://www.ford-trucks.com/forums/5...oday-pics.html
Old 06-21-2009, 05:12 PM
1_BIGMOFO's Avatar
1_BIGMOFO
Thanks a ton for the help..
Highmark18
33
03-04-2016 01:09 AM
Biggziff
75
08-25-2015 11:20 AM
mechmanf18
08-22-2015 12:35 AM
Ragzz
03-05-2012 03:03 PM
offshore1
17
11-25-2010 03:41 PM
Quick Reply: 08 - 09 Mirrors
