Computer swap questions
Has anyone swapped a computer from a new body style truck like a 2002 vdh5 computer into a 1996? I have got the truck running on it and had DI make me some files. It runs great. More power, a lot better throttle response. The main problem is the transmission wont shift. I can manually shift from 1st to 2nd but when I go to drive it just acts like its in neutral. Any info or tips are welcome! Wish it was a manual! LOL would be a lot easier!!!
Ive been doing some checking and the obs computer doesnt have the capabilities for higher horsepower tuning like the newer computers. Just the little bit that Ive run it it runs way better that my old computer ever did with a chip. I was running a 6pos. chip from DI before and just reprogrammed it with files for my new computer (vdh5) with single shot injectors. It runs way better. Better throttle response and definetly more power.
My other option if I cant get the trans to shift is go to a 6speed. Anyone got one they want to sell?
on
Well I would be lying if I thought that was really the case but none the less I would look at a pin out of PCM versus the wiring diagram of the Transmission. My guess is there is some pin swapping that needs to be done on the PCM connector.
Also isn't there a difference in the signal of the MAP sensor between the SD and OBS. I think the OBS is a HZ signal and the SD is a voltage signal.....
Im not sure on the map sensor. I had to make an adapter harness to switch the pins to match the new computer. I got a pin diagram of both computers and plugs and switched according to that. Thats a very long process. I checked for codes with my scan tool and the only ones I have are for the transmission turbine speed sensor and range sensor so im going to check my pins in the harness and switch them for the range sensor. I checked the data for all the engine sensors and they are all reading ok with my scan tool.
I was running a DI 6pos chip with their best files for the 96 computer and I also had the XSmoke setting!! IDM mod 10kmod with a switch, downpipe ,4" exhaust, custom cold air intake, 2002 hpop with crossover. Everything stayed the same when I switched the computer except for the tuning. The new pcm is a 2002 vdh5 and the tuning was done by DI last week. I have a aftercooler and 2000 intake manifolds to put on along with a bigger turbo and injectors this winter. I have a diesel performance business that I own so my projects get put on hold. Customers come first!! I have had several customers ask me about using a newer pcm like what I am doing so I decided to use my truck as aguinea pig and get it to work! If it does!!
