help
Old 09-15-2008, 09:22 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Connecting Rod? ouch if so! Or push rod? smaller ouch.
Old 09-15-2008, 09:23 PM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
Holy crap, that will do it. Piston not moving far enough to make compression to ignite the fuel, that will spew white smoke. But what I wanna know is how did you find that. Did you install the injectors and not suck out the oil enought and hydrolock it, then go back and suck it out?
Old 09-16-2008, 06:12 AM
roger99's Avatar
roger99
roger99 is offline
compression test it was around 180 pounds the rest 400 pounds
Old 09-16-2008, 07:27 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Big ouch!! that will do it for sure.
Old 09-16-2008, 09:06 AM
RubberDuck's Avatar
RubberDuck
Definately big ouch. If you don't mind me asking, what setup did you use to check compression. Tim and I have both talked about compression tools for our motor, but never really came up with a good answer. There are kits out there that said they would work on the PS, but I didn't buy one, and I don't think Tim did either.
Old 09-16-2008, 01:36 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I did end up getting one finally. I can't remember what brand it is though. It has a digital gauge and quite a few adapters.
Its this one (not from this place but this is the kit that I bought)
Mityvac MV5535 Digital Diesel Compression Test Kit
Old 09-16-2008, 02:19 PM
helifixer's Avatar
helifixer
helifixer is offline
Received 3,697 Likes on 1,136 Posts
thanks for the link Tim I book marked the page for when the budget allows me to buy one.
reps sent to you.
cheddar89
15
05-17-2012 06:15 PM
Engalwood
01-05-2012 10:18 PM
ckal704
Garage & Workshop
13
09-03-2009 09:38 PM
qtrmile
05-19-2007 08:16 PM
Matts72
Montana Chapter
03-24-2006 02:36 AM
Quick Reply: help
