white smoke
Old May 17, 2012 | 07:51 AM
cheddar89's Avatar
cheddar89
white smoke
My father inlaw has a 2001 powerstroke when he bought it it was hard to start and had to plug it in then it started missing and eventually got worse. We replaced the turbo twice glow plugs injectors idm and the sensor that goes into the head. Its not missing as bad anymore but blows white smoke. If we pul a trailer it seems to do fine. No white smoke .anybody have this problem or know what it might be
Old May 17, 2012 | 09:02 AM
Brother Les's Avatar
Brother Les
The color of the smoke some times will indicates what it is burning. Are you losing water? Are you losing or burning more oil than normal?
Old May 17, 2012 | 10:09 AM
CSIPSD's Avatar
CSIPSD
Bet it smells like fuel and burns your eyes...
Old May 17, 2012 | 10:48 AM
Joe28443's Avatar
Joe28443
Joe28443
I noticed mine yesterday and the fumes are stronger than normal.
Old May 17, 2012 | 11:30 AM
cheddar89's Avatar
cheddar89
Yes its fuel for sure waters fine and not really burning any oil its greyish blue
Old May 17, 2012 | 12:46 PM
CSIPSD's Avatar
CSIPSD
Broken Injector nozzle, cut o ring, bad copper...
Low/no compression...
Time to stop driving it, and figure out whats wrong before you buy a short block.
Old May 17, 2012 | 12:52 PM
cheddar89's Avatar
cheddar89
We pulled the injectors twice how do u test the nozzles we already buzz tested them 400 lbs of compression in every cylinder he dont drive it but up and down the road is all
Old May 17, 2012 | 12:59 PM
snakedoc's Avatar
snakedoc
i dont know if you can look at a injector cup and see it is leaking. they are in the heads when you pull the injectors.
the only way to check the injectors is to send them off and get the checked.
Old May 17, 2012 | 01:25 PM
cheddar89's Avatar
cheddar89
Well he just bought the injectors in febuary and smoked before and after he put the injectors in he got them from pensicola injetor
Old May 17, 2012 | 01:34 PM
Brother Les
<TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR title="Post 11844711" vAlign=top><TD class=alt2 width=125 align=middle>snakedoc</TD><TD class=alt1>i dont know if you can look at a injector cup and see it is leaking. they are in the heads when you pull the injectors.
</TD></TR></TBODY></TABLE
Old May 17, 2012 | 01:47 PM
CSIPSD's Avatar
CSIPSD
Biggest bunch of rip off artists on the net...
If it smells like fuel there are only a few ways to get that... Injectors, Injector O rings, or compression.
My bet is injectors. Did you replace the O rings every time you pulled them?
Old May 17, 2012 | 01:50 PM
cheddar89's Avatar
cheddar89
Nope but checked them and looked good do u think i should pull em again and send them to somebody if so who. And if the fuel pressure relife valve was bad what would it be doing
Old May 17, 2012 | 02:04 PM
CSIPSD's Avatar
CSIPSD
If you pulled the injectors without replacing the O-rings that is bad.
EVERY SINGLE TIME the injectors come out you should at least replace the copper crush washer.
If the FPR was bad it would not cause white smoke. Idle issues and hard starts, fuel pump noise and added wear...
Old May 17, 2012 | 02:14 PM
cheddar89's Avatar
cheddar89
Well when i crawled under there the other day and it sounded like the lift pump was gargling fuel and air and we changed it still sounds that way it takes about two minutes for the fuel pump to shut off
Old May 17, 2012 | 02:20 PM
CSIPSD's Avatar
CSIPSD
When you turn the key on the fuel pump should run for about 30-40 seconds without the truck running, then it will turn off.
You can drop the fuel tank and check the mixing chamber, there are screens in there that like to get clogged.
Still would not cause your white smoke issue. Your issue is from too much fuel reaching the cylinders, not a lack of fuel.
