2001 Headlight Switch Removal
There are 3 silver spring type retainers that hold it on. One is on the left side of the switch, one is on the top on the right had third of the switch and the other is on the bottom in the middle. There might be a 4th on the right side, but if you release the first 3 with a small screw driver you should be able to get it out. Pull the inspection cover off the left portion of the dash and you should be able to see the left hand clip.
Here is a link........ It is actually a modification to the switch but it shows you how to take it out.
Headlight switch mod
and here is a link to a previous thread about this
https://www.ford-trucks.com/forums/3...ight-****.html
maxndano
03-31-2014 06:37 AM
SeaCarr
10-21-2013 02:16 PM
