Sponsored by: Auxito
Headlights won't go off
Old Feb 20, 2006 | 09:20 AM
KennethKvittum's Avatar
KennethKvittum
2001 F-150 Headlights won't go off when i turn the switch off , all other lights due, this is the first time this has happened , had to pull the headlight fuses to shut the off ?
Old Feb 20, 2006 | 09:40 AM
Forddieselweasel's Avatar
Forddieselweasel
did you give it any time to turn off? i dunno if they all do it but my lariats headlights stay on for like 45 seconds after i turn the truck off
Old Feb 20, 2006 | 10:21 AM
7700Rob's Avatar
7700Rob
If'n you don't have autolamps, I'd point to the multifunction switch.
Old Feb 20, 2006 | 10:49 AM
KennethKvittum
I know it's not autolamps cause the guy next door called me half hour later when he came in and said i left my lights on.
Old Feb 20, 2006 | 05:34 PM
LxMan1's Avatar
LxMan1
Sounds like a bad GEM module. Look for signs of water/rust around the fuse panel and behind it (Gem Module). Sometimes a small, unknown windshield leak can cause problems.
Old Jun 2, 2011 | 02:31 PM
ww_dell's Avatar
ww_dell
Unhappy headlights stay on
Did you find the answer to why your headlights are staying on? My truck is now doing the same thing!!
I have a 2002 F-150 Supercrew with the 5.4 liter engine, and my lights turned on, “ON THEIR OWN”, with the light switch in the OFF position, while I was sitting in the truck with the engine running. This happened about 15 minutes after I had jumped off someone with a dead battery. My truck does not have Daytime Running Lights, so this should not be due to a faulty DRL module. The lights stay on all the time, even with the engine off, light switch in off position, and key removed. The only way I can get the lights to go off is to disconnect the battery. So far, I have tested these things:
- Cycled light switch multiple times, headlights still on
- Battery voltage is 12.7 volts while not running
- Alternator is putting out 14.38 volts when running, so is not for lack of power not driving a relay somewhere
- Removed wire from rearview mirror light-dimming feature, replaced and selected “off”, no difference, has power to mirror
- Checked “every” below-dash fuse, and tapped relays (did not know how to check them)
- Checked “every” engine-bay fuse, and tapped relays (did not know how to check them)
- Removed light switch from dash wiring harness, headlights still on with no light switch installed
- Wires running to light switch and to fuse block do not appear to be melted or overheated
- Lights do go out when I remove the engine-bay fuse #3 (main light switch)
- Lights do go out when I remove the below-dash fuse #26 (Right side low beam headlight)
- However, the lights DO NOT go out when I remove the below-dash fuse #28 (Left side low beam headlight)
1. Why would the lights go out when I remove fuse #26 but not on fuse #28? Does one fuse feed the other?
2. Can I easily pull out the fuseblock to check wires and connections behind it?
3. What wire location and pin-out should I be testing next to track down the source, assuming it is a crossed or melted wire?
Please feel free to email me directly at my crackberry at: dell.west@honeywell.com<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jun 3, 2011 | 12:28 AM
Blue_Betty's Avatar
Blue_Betty
Is it your high beams or your low beams that are on? If it is the high beams, maybe it could be you multifunction switch. Attached is the wiring diagram for the headlight circuit if that helps you out at all.
Old Jun 3, 2011 | 06:35 AM
ww_dell's Avatar
ww_dell
Smile
It's my low beams and all parking lights that are affected. My high beams still operate with the mulitfunction switch. Thanks for the diagram. I will definitly print it and use it. Dell
Old Apr 2, 2017 | 07:19 AM
Rightofthepeople's Avatar
Rightofthepeople
Hello Dell. I realize your post is almost 6 years old, but did you ever find a solution to your problem? I recently bought a used 2002 F-150 and am now experiencing the same exact issue! I disconnected the battery as my temporary solution. Please let me know what you found. Feel free to email me directly at camgarrett@yahoo.com.
Thank you!
Fish Eyed Fool
Nov 18, 2017 01:53 PM
Cory Barrow
Mar 13, 2017 01:16 PM
Lando25
Feb 4, 2017 01:19 PM
Klock09
Dec 8, 2016 07:03 AM
Talan
Dec 6, 2016 08:06 PM
