Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 ford escape headlight with moisture
Old Jul 6, 2001 | 01:25 PM
rweiss's Avatar
rweiss
Old Feb 17, 2002 | 08:08 AM
toohonest's Avatar
toohonest
I bought a used ford escape 2001 xlt and it has moisture in
the left headlight....any suggestions???
thanks
Ken
Old Feb 20, 2002 | 02:09 PM
Drawsoncad420's Avatar
Drawsoncad420
[updated:LAST EDITED ON 20-Feb-02 AT 03:12 PM (EST)]Try and find the cause of the moisture. Most ford headlight housings are pretty easye to tak out...well at least my old Explorer and my new Expedition housings are pretty easy. Condensation can only lead to more trouble. Water in the headlamp will cause you to go through numerous bulbs. Depending on the amount of water in the housing..if ice forms inside, you could be at risk of paying for a whole new housing.... if it cracks or splits. Most of the time the condensation will get in throught the seams of the housing. I would remove the Housing, let it dry out, look for any cracks, maybe even run a bead of sealant around the seams of the housing. If all else fails...id go to a scrapyard and try and find a wrecked Escape and get you new housing there...better than paying Ford for a new one.
Old Mar 9, 2002 | 03:08 AM
sprakties's Avatar
sprakties
Post 2001 ford escape headlight with moisture
Had the same problem. The headlight housing was not sealed properly on the top. Took it to Ford and they put in a new headlight assembly.
Old Jul 11, 2005 | 07:00 PM
Pejeeper's Avatar
Pejeeper
Same problem with the girl's 01....
Looks like I can get the bottom bolt out without removing the front bumper....can I really or am I over compensating my mechanic ability.....?
Old Jul 12, 2005 | 06:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Pejeeper and toohonest, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 12, 2005 | 05:35 PM
Pejeeper's Avatar
Pejeeper
Not the help I was looking for.....this sin't my first message board...I know how these things work...been on numerous Jeep boards in my time but this is the first time I've had to deal with a Ford.....
any help with this b4 I go ahead and do it my way?
Old Jul 13, 2005 | 12:41 AM
Racerguy's Avatar
Racerguy
I've only replaced a headlight once on an Escape and I removed the bumper cover.
Let us know if you figure out some way to do it without
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
