2001 Headlight Switch Removal
Old 09-02-2008, 06:38 PM
NBFDCap's Avatar
NBFDCap
NBFDCap is offline
I have a 2001 F150 SCrew and need to remove the headlight switch. Can someone PLEASE help me with the solution. Thanks Will
Old 09-02-2008, 06:58 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
There are 3 silver spring type retainers that hold it on. One is on the left side of the switch, one is on the top on the right had third of the switch and the other is on the bottom in the middle. There might be a 4th on the right side, but if you release the first 3 with a small screw driver you should be able to get it out. Pull the inspection cover off the left portion of the dash and you should be able to see the left hand clip.
Old 09-02-2008, 07:59 PM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
I thought you had to remove the **** and twist it a certain way to remove it?.. or maybe its different on a Screw?
Old 09-03-2008, 01:49 AM
streethealer's Avatar
streethealer
streethealer is offline
I think that just applies to 97-99 models.
Old 09-03-2008, 02:02 AM
jjlogue3's Avatar
jjlogue3
jjlogue3 is offline
Here is a link........ It is actually a modification to the switch but it shows you how to take it out.
Headlight switch mod
and here is a link to a previous thread about this
https://www.ford-trucks.com/forums/3...ight-****.html
Old 09-03-2008, 08:08 AM
NBFDCap's Avatar
NBFDCap
NBFDCap is offline
Hey guys....thanks for the help I'll give it a try today.
Old 09-03-2008, 05:12 PM
TEKWS01's Avatar
TEKWS01
TEKWS01 is offline
Don't do the headlight **** twist procedure.. I tried this on my 2000 and ended up breaking it... follow the clip unlocking procedure.
KennethKvittum
1997 - 2003 F150
04-02-2017 07:19 AM
maxndano
03-31-2014 06:37 AM
SeaCarr
10-21-2013 02:16 PM
rweiss
Escape & Escape Hybrid
07-13-2005 12:41 AM
FedExguy2004
Electrical Systems/Wiring
10-24-2004 10:16 PM
Quick Reply: 2001 Headlight Switch Removal
