Bending back the seam on the firewall
Hey guys, I don't have a powerstroke, but I'm putting a 3" downpipe on my truck and I have to bend back the seam on the firewall just like you fellas do.
So, I wanted to pick your brains and ask how you guys did it? I worked on it the other day with some vise grips and a piece of pipe. I bent back the outer edge of it, but it looks like it could use a little more.
I noticed that with enough force, the floor pan flexes instead of the seam bending. I was thinking about cutting it in a couple spots to make it easier to bend, but wasn't sure if that was a good idea...
Originally Posted by ghunt
Well like I said...I was using a long piece of 2 1/4" pipe with a bend in it, and when you really put force on it, the floorpan just flexed.
We assumed that you already showed it where to bend....
Originally Posted by heathrunkles
I didn't like trying to bendthe wall a long pipe. Kept popping off the v between the common rail and the valvecover. Since i don't have aport-a-power I took the small screwjack from my wife's camry. It fit perfect between the wall and the bell and opened the tunnel up with little effort.
[QUOTE=RÖENTGEEP]Here are the instructions:
http://www.drivetrain.com/downpipeinstinstr.html[/QUOTE]
excellent direactions
one concern though: that cut in Fig 3 is darn close to the turbo outlet. dont metal shavings get into the turbo when that cut is made with a reciprocating saw? I'd be real nervous making that cut.
Jeff and Nicolle
19
01-30-2016 06:34 PM
Johnny L
09-28-2014 09:54 PM
sdetweil
13
02-08-2009 10:50 AM
