Call out to you 5.0 EFI users
Old 01-28-2016, 09:09 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
I am wanting to see what you guys used for an accelerator pedal and do you like it?
I just ordered an EFI throttle cable and AOD throttle valve cable from BCBRONCOS. It is designed to run from the firewall around the front of the upper intake, allowing no harsh bends in the cables. I have played with different cables and running them along the firewall to the passenger side just creates too much bind...not gonna have that...
This set of cables are designed for the Early Bronco gas pedal, but I'm sure I can use something else since I don't have an early Bronco pedal. (had one in high school...'68...wish I still had it...) but lend me your experience.
Old 01-28-2016, 09:27 PM
thepitshop's Avatar
thepitshop
thepitshop is offline
Using 89 crown vic cable and s10 accelerator pedal, just stuff I had laying around
Old 01-28-2016, 09:45 PM
Jeff and Nicolle
Is your throttle body on the drivers side?
Mine is on the passenger side.
As I recall, the crown vics upper intake/ throttle body was on the drivers side.
And the cables were too short for my setup.
But the S-10 pedal worked out. Did you have to modify it at all?
Thanks!
Old 01-28-2016, 10:02 PM
schoo's Avatar
schoo
schoo is offline
I'm using the set up from a E250 (engine donor)I had to modify the petal bracket because the van pulled from in front of the engine I think it will work I haven't got the engine running yet
Old 01-28-2016, 10:15 PM
Jeff and Nicolle
I have two salvage yard pedals in the garage and can't remember what I got them from! LOL
I know they were Fords though.
Old 01-28-2016, 10:18 PM
schoo's Avatar
schoo
schoo is offline
Master installed
The cable is long from the 89 van I looked at my 89 f250 and copied the pedal and I think the cable in that truck could work, it's a 460 efi
Old 01-29-2016, 03:22 AM
55 f350's Avatar
55 f350
55 f350 is offline
d@^3 jeff i would'a thought you would've had that truck together and driving by now ................ well at least i'm not the only one dragging for whatever reason
Old 01-29-2016, 06:51 AM
thepitshop's Avatar
thepitshop
Your right it's on the drivers side,I did some minor bending.
Old 01-29-2016, 08:44 AM
OldGrayMare's Avatar
OldGrayMare
OldGrayMare is offline
If it helps any, that picture looks identical to the throttle setup on my 88 Bronco with a 302. 1987 through 1992 would all be the same.
Old 01-29-2016, 09:24 AM
tip49's Avatar
tip49
tip49 is offline
Stock 1990 Crown Vic cable
Jeff;
my linkage is on drivers side' using pedal from F150
Tom
Old 01-29-2016, 09:25 AM
49f3dls's Avatar
49f3dls
49f3dls is offline
I used the petal from the Jaguar I took the front end from. Had to bend it some put it worked fairly well. Sorry I did not take a picture of it.
Old 01-30-2016, 01:42 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
I used a spoon pedal from Speedway. My engine is from an 88 Lincoln Town Car. 5.0 L Lo Po. Good enough for me.
Old 01-30-2016, 02:00 PM
jerry_s's Avatar
jerry_s
jerry_s is offline
I'm assuming you're talking about the non-coyote/modular engines? For those, and I'm using the coyote, the FRPP control pack comes with a pedal that has to be used. You can't use a separate pedal as it has to be capable of controlling the electronic throttle.
Old 01-30-2016, 02:04 PM
Jeff and Nicolle
No Sir, sorry, I have a '96 5.0 out of an Explorer.
Old 01-30-2016, 03:16 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
I used a Lokar floor mounted pedal and cables, so far they work just fine. Also used the Lokar kick down cable for the AOD.
Quick Reply: Call out to you 5.0 EFI users
