Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Anyone Can Answer This???
Old 12-10-2007, 07:39 PM
HOGFISHHD's Avatar
HOGFISHHD
HOGFISHHD is offline
Question Anyone Can Answer This???
IF A ENGINE 1988 302 5.0L HAS GREAT CYLINDER COMMPRESSION
IS GETTING FUEL TO CYLINDERS , HAS NEW CAP & ROTOR , NEW COIL
BUT IS GETTING NO SPARK TO PLUGS , WHAT COULD BE CAUSING PROBLEM??
Old 12-10-2007, 11:15 PM
PatsPOS's Avatar
PatsPOS
PatsPOS is offline
Well, assuming you don't have any broken wiring, I'd say your next purchase should be a TFI module.
HTH,
Pat
Old 12-11-2007, 01:07 PM
06SUPERDTY5.4's Avatar
06SUPERDTY5.4
06SUPERDTY5.4 is offline
HTH,
Pat
this is the first thing that i would also try... i had one go bad on my mustang but the car would start when cold and not run after it got any type of temperature to it....
Old 12-11-2007, 03:58 PM
soondg's Avatar
soondg
soondg is offline
The shop guys say the module.
The board inside cracks and when it heats up it splits, so say the shop guys.
Other opinion, could be the pick up, but not likely.
Old 12-21-2007, 02:03 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
pop the module off and open it up, the circuit board inside is probably black aka shot.
54TexasF100
Projects
196
12-06-2021 09:17 PM
Maebeline
35
09-14-2016 07:17 AM
Alphund
13
04-07-2015 02:27 PM
Julies Cool F1
16
06-19-2010 03:42 AM
ubereal2
Missouri Chapter
06-07-2007 06:31 PM
Quick Reply: Anyone Can Answer This???
