285/70/R17 on My 2000 F150 Lariat
Old 11-29-2007, 01:13 PM
kdc642's Avatar
kdc642
kdc642 is offline
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have a stock 2000 F150 and am planning on putting 285/70/R17 tires on my truck that came with 265/70/R17 tires. I am not putting a lift on the front end and will probably only make minor modifications to my fenders (ie. sawsaw 1/2" off the plastic pieces underneath.
Has anybody put 285s on a stock F150?
</TD></TR></TBODY></TABLE>
Old 11-29-2007, 01:36 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Yes and they will not rub anywhere, assuming this is a 4wd. Just be ready for the sway bar end links to snap in half at some point. I lost 3 of them while I had those size tires on and never any with any other size. My brakes also wore out a lot faster with them on. They look great but are a bit hard on the front end.
Old 11-29-2007, 01:39 PM
xtrford's Avatar
xtrford
xtrford is offline
Yup.
Old 11-29-2007, 05:27 PM
kdc642's Avatar
kdc642
kdc642 is offline
thanks fellas....galaxie641 did you break you sway bar while offroading or under normal driving conditions?
Old 11-29-2007, 06:11 PM
kdc642's Avatar
kdc642
kdc642 is offline
Old 11-29-2007, 08:31 PM
galaxie641's Avatar
galaxie641
Normal driving. It is pretty common to snap them with bigger tires. NAPA sells a much better end link than Ford makes and it only costs about $30 for the pair. I should note the sway bar end links snap not the sway bar itself.
Old 11-29-2007, 08:41 PM
Ford51's Avatar
Ford51
Ford51 is offline
Whats the approximate Diameter of this size tire?
Old 11-29-2007, 08:50 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
Dimension Tire A: 285/70 R 17
Width 11.22" (285.00mm)
Sidewall height 7.85" (199.50mm)
Overall height 32.71" (830.80mm)
Circumference 102.76" (2610.04mm
steve(ill)'s Avatar
steve(ill)
Old 11-29-2007, 09:13 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
that's why you buy Moog chassis parts
Old 11-29-2007, 09:49 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,740 Likes on 1,330 Posts
Yup...285's fit with no problem. I've had 34's on my stock truck with no rubbing either.
The sway-bar links...after one of mine broke, I just took it off. There's no need for it. The truck doesn't "roll" more without it than it did with it...never changed the handling at all. Plus, you'll get a little better flex while offroad, and a smoother ride over the rough stuff.
Old 11-30-2007, 08:34 AM
ScreaminZ's Avatar
ScreaminZ
ScreaminZ is offline
I've never tried running my '99 without a sway bar, but my '92 F-150 4x4 didn't even come with a sway bar from the factory. Rode just fine and took the turns just as well as my '99.
clouden
1997-2006 Expedition & Navigator
05-02-2011 12:05 AM
thedaddycat
Oil & Lubrication
02-27-2008 06:12 AM
fordkev
3.8 & 4.2L V6
02-09-2008 06:33 PM
brianstacy
04-16-2007 11:25 PM
blacksheep123
04-05-2007 12:00 PM
Quick Reply: 285/70/R17 on My 2000 F150 Lariat
