4R100 troubleshooting (NOT E4OD)
Old Mar 4, 2007 | 10:27 PM
clouden's Avatar
clouden
4R100 Troubleshooting
<HR style="COLOR: #666666" SIZE=1><TABLE><TBODY><TR><TD vAlign=top width="100%">basics: 2002 EB EXP. 2wd 5.4L auto 4wh discs 90000 miles
checked-good; trans fluid: red, smells good, looks good, no grit, full
rear discs: new
parking brake: adjusted properly
Initial concern;
when starting the vehicle in park, sometimes, there is a slight jerk, or lurch forward. (normally when e-brake is applied before shutting the engine off). the wheels dont spin, just drivetrain moving. then when put into reverse, to back up, the vehicle responds as if the e-brake is applied, taking a lot of throttle to move. It gets a little easier the further you back up, (a long driveway versus a parking spot) ALL forward gears operate flawlessly.
My first thoughts were ebrake, or something related hanging.
I lifted the truck off the ground and began testing......
PARK- when vehicle started in Park, occasional wheel movement, (i.e SLIGHT jerk forward)
REVERSE- when put in reverse, at idle wheels do not spin, you must give it gas, even then it acts restricted.
NEUTRAL- when put in neutral, wheels begin to turn slowly at idle. If gas is applied, wheels spin very quickly. Once spinning, the wheels do not respond differently to various throttle postions, (i.e no faster with more gas) you can stop the wheels by hand, but they eventually start spinning again.
DRIVE- the transition from N to D is barely noticeable, other than the wheels now respond to the various gas positions.
I have tried to pull codes from the main OBDII plug, none stored. I disconnected the linkage from the column to the trans and shifted manually at the trans mounted switch, no difference.
Is it possible that the trans mounted switch is bad?
the torque convertor?
the "layshaft"
what is wrong with it? any thoughts, experiences? HELP!!!
when put into reverse, it acts as if it is fighting against the forward movement slipping thru. idleing off the ground the wheels pulsate, or shutter.
</TD></TR></TBODY></TABLE>
Old Apr 14, 2010 | 05:43 PM
generaltso64's Avatar
generaltso64
mlps/neutral safety switch on side of trans is off adjustment or bad
Old Oct 20, 2010 | 03:59 PM
AZ Elk Hunter's Avatar
AZ Elk Hunter
Mine just started doing this today. Can someone please help me on where this sensor is and how I can check for adjustment?
When I put the truck in reverse it does not move under idle. If i give it pedal, it acts restricted. I put the truck in neutral and it creeps forward.
Old Oct 20, 2010 | 07:17 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
I would guess that the shifter linkage is out of adjustment.
Old Oct 20, 2010 | 10:14 PM
AZ Elk Hunter
I replaced the mpls with no success. I also checked the linkage and it is correct. Anybody else?
Clouden, if you are out there, please let me know what was wrong with yours. Mine is doing the same exact thing!
Old May 2, 2011 | 12:05 AM
poweredstroked's Avatar
poweredstroked
When you find out let me know too. I changed fluids and filter in trans. And had alot of metal And black crap.
77_150_460
Jan 25, 2010 06:14 PM
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
savage2211
Ride Of The Week
Mar 8, 2009 06:52 PM
SeminoleSlim
25
Jul 15, 2008 10:32 PM
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
