Block heater ?
on
Use a good 12 or 14 gage extension cord. The shorter the better. Temps depend on how well your truck starts in the those temp. if it starts good don't plug it in. starts hard or you want heat in the cab faster plug it in. I use a heavy duty outdoor timer to run mine when I use it. Set it for 2 or 3 hours before you leave for work and that way your not spending extra on electric. though the block heater really doesn't cost much to run but it adds up.
That cord can be replaced on that heater, if it goes bad. Flapping on the bumper
will start to bust the wires inside the insulation.
Pull the clip off the heater end, that keeps it on the heater. Do a continuity check
on the cord, before you take it out of the truck.
They are about $35 bucks at Autozone, or $75 bucks at Ford.
paulhump
6.4L Power Stroke Diesel
04-05-2017 03:02 PM
wmiller
35
11-23-2008 06:51 PM
