Coolant flush for weeks! Question
Old Mar 17, 2016 | 10:30 AM
Waterlogged's Avatar
Waterlogged
I have been doing a very serious coolant flush now for two weeks. I get more stuff out with every flush. Lots of rusty iron chunks. I have both block plugs open and I'm backflushing the oil cooler and the heater core. I keep thinking that eventually I'll stop getting trashed but it just keeps coming. My question to the experts out there is where is the stuff hiding? Radiator? Heater core? Block? Or all of the above? Thanks for any advice as it may help in getting the crap out.
Waterlogged
Old Mar 17, 2016 | 12:09 PM
KIDkiser's Avatar
KIDkiser
Have you done a chemical flush such as restore or vc9?
Old Mar 17, 2016 | 12:37 PM
Waterlogged
I did. Restore, then restoreplus, then i drove it for 2 days with a pint of dawn in it. Each time breaking plenty of stuff loose, with perhaps the dawn dish detergent getting the most stuff out.
Old Mar 17, 2016 | 12:53 PM
Per4mance's Avatar
Per4mance
I'd take the hoses off the heater core and radiator and flush it with the garden hose. Then i'd take the thermostat out and make a rubber fitting to connect the garden hose to the thermostat housing and pull the block plugs and just run the hose til it clears,then do a chemical flush again and repeat the garden hose flush til clear and then do the distilled water flush. Also I'd use the IPR coolant filter due to the fact that this engine has issues with rust.
Old Mar 17, 2016 | 08:39 PM
BLADE35's Avatar
BLADE35
Its Also just rusting out on its own
Better Hit it with the Garden hose then do a VC-9 High Idle for an Hour thermostat OUT
Some had success with a Radiator cleaning
And get the Coolant Back in it ASAP!!! It sounds like your Cavitating the Block
Cavitation Happens Very Fast with NO Coolant its Literaly Tearing itself apart
Old Mar 21, 2016 | 11:03 PM
Tennesseepowerstroke's Avatar
Times 2..........................
Old Mar 22, 2016 | 12:46 AM
BBslider001's Avatar
BBslider001
Good grief, that's ridiculous! Tearing itself apart that fast? Wow...
3000gtman
18
Jan 22, 2017 04:25 PM
tkerkela
Oct 4, 2016 02:27 PM
Waterlogged
Mar 14, 2016 08:25 AM
CheaperJeeper
Apr 25, 2007 12:07 AM
zionatdirt
Apr 8, 2005 11:34 AM
