Goofy question
Old Feb 18, 2016 | 07:12 AM
FatOldGuy's Avatar
FatOldGuy
Goofy question
I'm installing the engine block heater in my truck... what type of sealer do I need for the threads? Teflon tape?
Old Feb 18, 2016 | 07:42 AM
SavageNFS's Avatar
SavageNFS
I've used teflon tape before. Just stay away from the end so no pieces of tape can tear off and enter the system.
Old Feb 18, 2016 | 08:40 AM
Superduty450's Avatar
Superduty450
If you use Teflon Tape make sure to put 6-7 wraps on the threads, or use Teflon Pipe dope.
Old Feb 18, 2016 | 10:38 AM
FatOldGuy's Avatar
FatOldGuy
Thanks guys, just wanted to make sure.
Old Feb 18, 2016 | 04:15 PM
FatOldGuy's Avatar
FatOldGuy
This stuff is sufficient?
Old Feb 18, 2016 | 04:21 PM
SavageNFS's Avatar
SavageNFS
Yes, that will work just fine.
Old Feb 18, 2016 | 04:38 PM
twigsV10's Avatar
twigsV10
Generally block heaters have a gasket or an O-ring and don't require thread sealant? It probably won't hurt anything but that's just my experience.
Old Feb 18, 2016 | 04:50 PM
FatOldGuy's Avatar
FatOldGuy
OK... I was just going by this install video.
Old Feb 19, 2016 | 12:09 AM
strokin83's Avatar
strokin83
Yea there's no need to teflon the threads. I installed a block heater in my 2013. It has a think O-ring so you just thread it in and tighten it down. Just make sure your ready like quick draw Mcgraw when you pull the block plug out. It'll make huge mess unless your quick.
Old Feb 20, 2016 | 08:51 AM
Ford_Doctor's Avatar
Ford_Doctor
The 6.7L block heater has a rubber o-ring that seals it to the block. No additional sealants required or recommended.
Old Feb 20, 2016 | 07:05 PM
FatOldGuy's Avatar
FatOldGuy
Yep, you guys were correct as usual. I hadn't actually looked at it until I started to install it today, there was an O ring. Thanks again for all the great info!!
Of course I installed the Engine Block Heater and the Wolverine Oil Pan Heater and it was in the 70s today. I had to take a lunch break with the wife and ride the Honda Valkyrie to lunch. It sure felt good to get a ride in with the 1800.
It also felt good to get both heaters installed and ready for the next cold snap, whether that's in a week or two, or next winter.
Old Feb 22, 2016 | 09:49 AM
troverman's Avatar
troverman
Huh - I was under the impression all 6.7L's came with a block heater built in, some needed to purchase just the cord?
For me in a cold weather state, block heater and supplemental heater were freebies...
Old Feb 22, 2016 | 12:18 PM
FatOldGuy's Avatar
FatOldGuy
Yep, I don't know which states are considered "cold weather", but Missouri must not be. I live in Illinois, but purchased the truck in Missouri.
Old Feb 22, 2016 | 12:57 PM
troverman's Avatar
troverman
So, you're saying not even the actual element is installed in the block in place of the freeze plug?
There goes my theory. It seems unfair to "give" some freebies to those in cold weather states, but not to those everywhere else.
Here are the Ford-designated "cold weather states:"
AK, CO, IA, ID, ME, MI, MN, MT, ND, NH, NY, SD, VT, WI, WY
On the "build and price" pages from Ford, the block heater is listed as no charge for the above list of states. Interestingly, the $250 optional rapid supplemental heater is not listed as standard in cold weather states, but my window sticker shows "no charge" for it (bought in Vermont).
Well, good luck with installing yours.
Old Feb 22, 2016 | 02:50 PM
FatOldGuy's Avatar
FatOldGuy
I agree it seems weird to charge some and not others. But I got it installed over the weekend, so I'm good to go now.
