1st Oil Change
Originally Posted by dfresh27
What's the school of thought on changing the oil after the first 1000 miles to remove any particles from the manufacturing process? Does this really help?
I changed mine at a 1000 miles. I figure, what the heck, it is cheap insurance. I also figured that the truck has set on the lot for at least a couple months also. I then change mine at 3000 miles where alot of people wait to 5000 miles. I guess it's all in what you are used to doing.
Good luck with that filter because it's a BEAR!!! There have been several posts about how's the easiest way to remove it is. Do a search and you should find it.
Originally Posted by pepito113
Yeah I also did my first oil change at 1,000 miles. And the filter was way too tight
I did the my first oil change at 1,000 miles as well, that is when I went to the Napa Gold (WIX) oil filter, I also purchased Napa's oil filter "cup" which attaches to your 3/8" ratchet. I do my oil changes every 4,000 now and it is quite easy using the oil filter "cup" and 3/8" ratchet.
One thing Ford engineers did that was a nice pleasant surprise is they installed a plastic oil deflector. So when you remove the filter the oil doesn't drop down onto the axle housing making a mess.... You make your own mess when you don't use an oil pan that is wide enough to accommodate both drip points of that plastic deflector...
Crewcab Turbo
18
09-17-2011 02:25 AM
