Need source for fuel sender float
My gas gage stopped working again this week. It is the fuel sending unit. The brass float is full of fuel once again. This happened three times before (in last 4-5 years). First two times I replaced the sender assembly (about $100 each). Last time I drilled the float, drained it, and resealed with epoxy. Lasted 6 or 8 months.
Is there a source where I can get just the float? Perhaps a non-brass, solid float (material like float in Holley carb). If not a cheaper place to buy sender assembly would be appreciated.
1982 F250 (19 gal. saddle tank)
Thanks
Mike
Thanks
Mike
I was in a pinch once on an old car I was fixing up, and I actually used a carb float on the end of the arm. I used some soft steel wire I had to mount it on the arm. Worked for me.
I just had a thought. I have never had a problem with the float in my truck, and I was wondering why you do? Could your float actually be rubbing the tank somewhere?
Fordmaster06
05-05-2012 03:57 PM
Mobro21
05-28-2011 03:55 PM
924x2150
18
08-29-2005 09:49 PM
