Need source for fuel sender float
Old Dec 11, 2002 | 04:15 AM
mshumack's Avatar
mshumack
My gas gage stopped working again this week. It is the fuel sending unit. The brass float is full of fuel once again. This happened three times before (in last 4-5 years). First two times I replaced the sender assembly (about $100 each). Last time I drilled the float, drained it, and resealed with epoxy. Lasted 6 or 8 months.
Is there a source where I can get just the float? Perhaps a non-brass, solid float (material like float in Holley carb). If not a cheaper place to buy sender assembly would be appreciated.
1982 F250 (19 gal. saddle tank)
Thanks
Mike
Old Dec 11, 2002 | 06:56 AM
Jens's Avatar
Jens
Hi Mike,
correct me if I'm wrong, but isn't it possible to do a good solding job to fix it?
Jens
Old Dec 11, 2002 | 01:11 PM
Franklin2's Avatar
Franklin2
I was in a pinch once on an old car I was fixing up, and I actually used a carb float on the end of the arm. I used some soft steel wire I had to mount it on the arm. Worked for me.
I just had a thought. I have never had a problem with the float in my truck, and I was wondering why you do? Could your float actually be rubbing the tank somewhere?
Old Dec 11, 2002 | 09:02 PM
electricmaniac2's Avatar
electricmaniac2
I went to my local Ford dealership parts dept. the brass floats came in a 2 pack and weren't that expensive.
Old Dec 11, 2002 | 11:04 PM
blownbronco's Avatar
blownbronco
Go to a junk yard take one off a sending unit and tell the guy you found it on the ground. He will probably charge you 5 bucks!! That's what I did!
Old Dec 12, 2002 | 12:26 AM
Superdave's Avatar
Superdave
Old Dec 12, 2002 | 03:58 AM
mshumack's Avatar
mshumack
If the dealer has the float I would prefer that option. I didn't know they were available speparately - especially for an old truck. Thanks for the tip.
dynamic
Jul 9, 2012 10:25 AM
Fordmaster06
May 5, 2012 03:57 PM
Mobro21
May 28, 2011 03:55 PM
924x2150
18
Aug 29, 2005 09:49 PM
