Fuel Sending Unit
Old May 28, 2011 | 06:53 AM
Mobro21's Avatar
Mobro21
Fuel Sending Unit
Hi my question is about the float on a fuel sending unit. The truck is a 85 f-350 which originally had a 460 with I think the hot fuel option. The rear tank sending unit show empty all the time, so I removed the sending unit and found the float was not attatched to the sender. My question is what holds the float rod, which is still on the float, in the turning part of the sender. The rod has a flat spot on it I thought might set in a slot in the hole in the sender but the sender appears smooth inside. Any help would be appreciated.
Old May 28, 2011 | 09:09 AM
fellro86's Avatar
fellro86
The rod is held in by a piece of plastic which acts as a pivot bushing. It essentially is bonded, so it should not have come out.
Old May 28, 2011 | 12:38 PM
Mobro21's Avatar
Mobro21
OK thanks. I found where it pivots and that part appears to work. When I rotate it the guage moves. I was just wondering if I was missing a clip or something that held the rod in it. Is there any way to glue the rod back in?
Old May 28, 2011 | 01:53 PM
fellro86's Avatar
fellro86
You probably could. Never done such, but it should work.
Old May 28, 2011 | 03:55 PM
Mobro21's Avatar
Mobro21
OK thanks I'll try it
petermck
Nov 21, 2016 06:33 PM
john jamieson
Sep 11, 2016 02:42 PM
351Cleveland C4
25
Sep 9, 2016 10:32 PM
annaleigh
May 27, 2015 07:29 PM
gissmo2
Mar 18, 2014 07:34 PM
