'93 Intake
'93 Intake
I am looken to get an intake kit for my '93 Ranger 3.0L. I have not been able to find any kits on the internet, does anyone know of a place that has one or have any advice as to how to create my own?
Also, I am wondering if this is something that I should put my $ into, or would it be better to just invest in exhast.
If you want a fairly cheap intake solution you could allways drop a k&n panel filter in, remove the silencer cone in the airbox, and cut another hole in it as well, then this site http://www.ssd4u.com/streetsmart_006.htm sells larger diameter tubes. (haven't actually bought a tube I'm about to buy some mandrell bent pipe and weld up my own, Just have to find some 3" rubber hose for gasket material. hmmm
Originally Posted by felixdacat76
I had read somewhere that an air intake kit from a Civic would work in a '93 V6 3.0L. Just wondering if anyone knows more on that, because I'm not especially crafty but would like an air intake in my Ranger as well. Any help would be appreciated!
FWIW, this is how one guy did it on his '94 4.0L. Maybe it'll give you some ideas on how it can be accomplished on the 3.0L:
http://www.geocities.com/drewcoffey/Truck/airintake.htm
This might seem like a real dumb question, so pardon me before I even ask it. Can you swap an MAF on a 3.0L with that of a 4.0L, or would that cause some problems? The reason I ask is that I am trying to build a seat from the MAF to a cone filter for some cold air intake, but can't seem to work the PVC seat from that mod above to work on the 3.0L MAF. Any help would be greatly appreciated!
93F250
03-30-2005 10:21 AM
