dirty transfer case fluid
Hello, couple of questions on my 04 XL transfer case, 107,000 miles new to me, as I took out plug to check level air was sucking in around the threads like the case was sealed air tight, is there a vent that is plugged or is it sealed tight?
Next thing was that the fluid was muddy brown, smelled like atf but looked crappy brown. Didn't look foamy like water, I guess it's troubling if it's heat related, I'll put clean fluid in and see what happens.
Most of them take ATF. If yours does, try Valvoline Max Life Dex/Merc. Best ATF out there. When I had a Jeep Cherokee, I changed the transfer case ATF after a couple of years and it was pretty dark. Subsequent changes were much better. And it doesn't matter if you ever use 4WD or not - it still gets used up.
fishbones182
1999 to 2016 Super Duty
12-30-2015 07:24 AM
straightsixer
04-21-2008 03:37 PM
stepside64
03-26-2004 11:00 AM
