what's this box? in my truck
So when I bought my 2001 ccsb 4x4 f250 7.3 it had a small box beside the steering wheel with a on/off switch & 6 position turn dial it has two wires coming off it black wire grounded under the dash and a red (+) wire that is cut, with no sign of where it use to go. I thought it was a tuner put have since pulled the pcm and it still has the silicone on the plug that all the tuners use. And the guy I bought the truck from had no idea what it was either he did say that the guy he got it from did at one point have an exhaust brake on it I was wondering if it has anything to do with that? Any other ideas?
There's also a red LED beside the box
A six position rotary switch like that is very typical of the Banks 6 Gun Tuner, but could also be used with other tuners, depending on how many tunes a chip might have had programmed. So your initial assumption sounds right.
Based on your description of the PCM though, it just raises more questions. Did the PCM actually have silicone on the terminals? Could it have been dilectric grease? The original protective coating on the boards isn't silicone, unless I'm mistaken. It's a much firmer, and yellowish coating, almost like an epoxy. If it was anything other than the original coating, I would still suspect it was from a tuner that was since removed, but should have had more than just 2 wires coming from the back; more like 7 or 8.
There's also a possibility that it's a 6 position rheostat, and that would explain why it only has the 2 wires. In that case, it could have gone to lights or anything else that would use a dimmer type switch. It looks like the box is a small electronics hobby box, like from Radio Shack, and not even mounted level with the lines of the dash board. I would be weary of anything installed like that.
For the OP: I hope you figure out what it was for, just to satisfy your curiosity if nothing else.
We? Who is "we?" And what is being gotten?
If I did, then it's because I misunderstood. If I did misunderstand, apologies. It isn't the first time, and I can guarantee it won't the the last time I read a post wrong.
Yes, I know, that's why I qualified my statement by saying that the coating has always been referred to as a silicone coating, not that is was made of silicone, that way it was clear to the OP he still had the original coating.
I never claimed it was silicone, but here is where I think I got confused.
I thought you were asking for the identifying nomenclature for what the coating is called, not asking if it was literally the same chemical compound as silicone.
Before I posted what I thought was the answer to your question, I double checked DP Tuners install page to make sure I wasn't remembering the terminology wrong.
I had good intentions. I didn't mean to ruffle your feathers.
Stewart
and thanks for quoting me out of context.
I understand its been called silicone. Just because it's been called that, doesn't mean that it actually is.
Silicone, by definition, is resinous and rubbery. The coating on the boards is not. Therefore, it may be commonly referred to as silicone, but chemically speaking, it doesn't have the properties of true silicone.
Stewart
Ben Samways
10-23-2017 08:40 PM
