Air Bag Warning light
12=Low Battery Voltage
13=Air Bag Circuit Shorted to Ground
14=Primary Crash Sensor Circuit Shorted to Ground
21=Safing Sensor Not Mounted to Vehicle Properly
22=Safing Sensor Output Shorted to Battery Voltage
23=Safing Sensor Circuit Input Feed/Return Circuit Open
24=Safing Sensor Output Feed/Return Circuit Open
32=Driver Side Air Bag Circuit High Resistance or Open
33=Passenger Side Air Bag Circuit High Resistance or Open
34=Driver Side Air Bag Circuit Low Resistance or Shorted
35=Passenger Side Air Bag Circuit Low Resistance or Shorted
41=RH Primary Crash Sensor Feed/Return Circuit Open
42=LH Primary Crash Sensor Feed/Return Circuit Open
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
52=Backup Power SupplyVoltage Boost Fault
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault -- these are for a 98 ranger ,,, close as I could get to your 96 ,,, sounds like the passenger side plug under the seat could use a good spray of contact electrical cleaner ,,, some sites said it was driver side,,, but not sure what year that was for,,, but it is a place to start ,,, also there are youtube videos on this,,, might want to watch one or two,,, hope this helps
From your description it sounds like it's blinking a 33 code. If so, that's for the passenger side air bag if the vehicle is so equipped. The passenger side under seat air bag electrical connector contacts are a common problem area. So disconnect the battery & leave a door open, or turn a light on for a bit, to discharge any remaining stored electrical system charge, Before disconnecting the air bag electrical connector to inspect its pins, sockets & wiring for looseness, corrosion or damage. Also try cycling the air bag deactivation switch off & on a few times to clean its electrical contacts.
More thoughts for consideration, let us know what you find.
