Dashboard light is flashing. Sometimes it flashes sometimes it doesn't:no real pattern. Any suggestions?
It just started with no accident or jarring. Thanks!!
1998 F150 5.5 V
When you turn the passenger airbag on/off, does the indicator light up? I forget what the code was, but when I posted the flashing code the good people here steered me towards my light bulb being burned out in the passenger airbag switch. If so, don't buy it from the dealer, you can buy a $2 LED at Radio Shack and fix it yourself. Last time I checked, they said you have to buy the whole switch!!! Over $75 for that! Good luck!
"Prolog: If you get one of these stupid Code52's "most of the time" this happens when the battery is disconnected. Only mid-90's stangs throw codes when that is done."
found my a/c blower runing with the ign switch of on my 97 expedition when i turned the truck on the air bag light started flashing 5-2 and then stays steady, what does this code means
The RCM (Restraints Control Module) checks the integrity of the warning lamp in the PAD upon startup. If the RCM detects that the bulb is open, it flashes the main SRS warning lamp with a LFC (Lamp Fault Code) 27.
In other words, the warning lamps have to work in order for the system's integrity to be intact.
You have more serious problems than only the airbag system. If it's been raining, you probably have a windshield that is leaking into the GEM module and fusebox.
hey guys, thanks for your help. got a code reader from a friend the hole problem was caused by #2 mini fuse on engine compartment. reset the computer and is all good now
