air bag light flashing?
Old May 17, 2010 | 07:53 PM
shark1979's Avatar
shark1979
i was driving my 01 ranger the other day when the air bag light started to flash 3 or 4 times and then stayed on. What would cause this to happen. where do i start looking ?
Old May 17, 2010 | 11:47 PM
g_k50's Avatar
g_k50
Error in system, have the Diagnostic Trouble Code (DTC) read by competent able mechanic, (Ford).
Old May 18, 2010 | 01:51 AM
fiddler59's Avatar
fiddler59
Trailering
A common problem for air bag light flashing is a burned out light on the passenger air bag disable switch.
Old May 18, 2010 | 07:10 AM
Rockledge's Avatar
Rockledge
If the airbag lamp is still flashing and then staying lit, then there is a two-digit code stored. Counting the flashes and it tells you the code number. For example, code 27 would be two flashes, a pause, and then seven flashes.
Old May 30, 2010 | 08:57 AM
Nite Ranger's Avatar
Nite Ranger
Ditto. Been through this on my 99. Instead of $100 plus for a new board in the switch go to Radio Shack or others and pickup a new bulb and solder it in yourself for less than $3.00.
msrtechtampa
Aug 14, 2016 06:17 AM
miuwcm3
Apr 10, 2014 12:16 PM
sadyedog1
Jul 11, 2011 05:29 AM
billydsr25
Escape & Escape Hybrid
Apr 2, 2011 04:50 PM
whruppe
Aerostar
Jan 16, 2008 09:05 PM
