what's going on?
what's going on?
OK my work truck completely stock( check my SIG) is throwing me codes P0603(internal control module keep alive memory malfunction, p1211(ICP higher/lower than desired), p1105(dual alt upper malfunction), p1106(dual alt lower malfunction)
The most concerning to me is the p1211 as the truck feels sluggish and CEL turns on at wot. I still have the OEM injectors and O rings, can this be caused by a blown O ring? The fuel filter is clean not a spec of black or anything, not burning oil, and start instantly cold or hot. The ICP was changed with a motorcraft one so is the IPR, the cps is the grey one a year old also a motorcrapt one. I'm leanings towards the hpop, but I still got to trouble shoot.
What vitals do I look for? My laptop cant be unplugged because the battery don't work, can this test be performed sitting still power braking? ( note I can't spin the wheels if I power brake before it could)
It depends on how severe the leak is, but if an o-ring is breached it will keep eroding and get worse over time. At some point it will probably get hard to start warm if that's what the issue is.
Last edited by Pikachu; 06-24-2016 at 11:00 AM. Reason: Removed word that was erroneously autocowrecked.
davewild
13
01-17-2016 09:29 PM
Hoosier 7.3
07-03-2015 11:07 PM
