Brake Pads Needed
Your first mistake was going to Autozone. That's a toy store. Go to Napa if you want quality parts. That said, I just picked up some semi-metallic (mid grade) disc brake pads for like 35-40 dollars. They will last years and years and don't squeak. I almost went with ceramic but they were quite a bit more and I didn't feel it was necessary.
Buy the best pads you can get your hands on. I like NAPA, will buy from Advanced Auto or O'Reileys in a pinch, NEVER from Auto Zone. I've been a rural mail carrier for 20+ years and will tell you there is most certainly a difference in brake pads. I replace brakes 2-3 times per year. The $70 pads are more than twice as good as the $35 pads. Last longer, stop faster, less noise, less mess. You definitely get what you pay for.
If you don't have brake lubricant, buy some. I think Advanced Auto has a container of it for around $17. Pricey, but it will last you a lifetime. This will help ensure your pads wear evenly and correctly. If your caliper isn't moving as it should your brakes will wear prematurely. You can put it on the back of your pads to help prevent squealing. Just keep it off the pad material itself, bad mojo there.
I put Power Stop brakes on my vehicles. I get them from Rockauto.
These are the specific pads on my truck right now.
https://www.rockauto.com/en/moreinfo...=7&jsn=7&jsn=7
TheKirbyMan
07-28-2013 07:17 AM
