Shift Detent Plate
So yours is for a 65/66?
Im aware that the culprit may be the shift lever, but I want to have all the bases covered when I pull it apart.
I forgot to order the horn spring, so Im waiting on that.
I cant get the roll pin out to remove the shift lever. I broke a drill bit off in there. Can I remove the lever and collar as an assembly?
1961/64 uses a different A/T shift collar than 1965/77. 1978/79 is different again.
Tom
Ive got all the parts. Im replacing the turn signal harness, horn ring, shift detent, and fixing anything else I find in there that needs fixing.
Since the wheel is going to be off Im pulling the cluster and doing some more work back there. My neutral start wiring is disconnected for some reason and I want to figure out why my gen and oil lights don't work. When I bought the truck there were gauges, I think the wiring is gone. The fuel and temp gauges still work. I bought the oil sending unit and a t-fitting so I can run the light and gauge if I can figure the wiring out.
Its just easier to work back there without the wheel and shifter in the way.
