Could someone give me the method (probably super easy) to remove the shift lever before the transmission is pulled from the truck? Someone did mention about twisting something until two pins unclip but I am sort of lost!
Get a second set of hands. I used a wrench to hold down the cap and helper tapped the cap counter clockwise with a robertson screwdriver. MAKE sure transmission is in neutral as it will eliminate future swearing.
With black **** at top removed, i slid a roll of electrical tape over shaft and pushed down on roll of tape, and tape on roll, provided enough friction to turn cap.
