crown vic parts.
Old 12-05-2015, 04:05 PM
460harris's Avatar
460harris
460harris is offline
crown vic parts.
I have a 1979 ford short bed two wheel drive. Right now it has a 302 motor with a c4 behind it. I'm wanting to swap over to an aod. I found a 84 crown vic that is in real good shape with good motor and transmission. My question is what to do with rest if parts. Would the front end work for my truck or any other vehicles wanting a crown vic suspension swap. What about rear end ? Thanks in advance
Old 12-05-2015, 04:21 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
If you actually look a the front suspension of that CV you would see that it is integral to the frame - not on a subframe like the 03-12 CVs. It is usable only if you graft (weld, box, plate) that CV's frame to your frame.
Yes on the engine and trans... But the trans is an early AOD.
Rear end? Dunno. Whip out your tape measure and then fire up a 220V welder for some quality time cutting and fabricating.
Old 12-05-2015, 04:30 PM
460harris's Avatar
460harris
So the front suspension on the cv is not as desirable as the later models? And yes the aod is early which I'm putting on a carb motor and from what I've gathered,from a link to hemming, is what I need.
Old 12-05-2015, 05:11 PM
HIO Silver's Avatar
HIO Silver
"Desirable" is a relative term. The 03-12 CV doesn't involve very much fabrication whereas grafting a frame requires much more detailed work.
Not all AODs are created equal. The later versions' internals are better. Both require careful calibration of the TV cable but no electronic controller.
Old 12-05-2015, 06:58 PM
jim collins's Avatar
jim collins
jim collins is offline
I want to second that on the TV cable , i have one in my 73 and it is very touchy easy to get out of adjustment. I would never go with an early AOD again . Step up to some thing better maybe an AODE and get a controller for it.
Old 12-05-2015, 10:01 PM
460harris's Avatar
460harris
Thanks for the info on the older tranny.
johnson.jeff.a
34
11-07-2015 12:30 PM
AmeriKen
38
11-14-2011 02:19 AM
amy_78
06-05-2010 03:42 AM
woodyf1
10-30-2008 09:38 AM
KP1479
10-20-2003 08:24 AM
Quick Reply: crown vic parts.
