Down pipe clearence issues.
Old 11-24-2015, 06:10 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
Sounds like its time to put some relief bends at problem spots.
Old 11-24-2015, 06:14 PM
DanielT28's Avatar
DanielT28
DanielT28 is offline
Probably. So that means I have to take my whole exhaust system apart just to get the downpipe off?
Old 11-24-2015, 06:19 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
You don't have to take the whole system off. You will however, have to remove the tranny crossmember and put a jack stand or two under the tranny and xfer case.
Old 11-24-2015, 06:24 PM
DanielT28's Avatar
DanielT28
That sounds like a big pain. But I see what you're saying. Start there. And then if it still does it I may have to remove system
Old 11-24-2015, 06:33 PM
sudsmcduff's Avatar
sudsmcduff
sudsmcduff is offline
My mbrp 4" to 5" hits the same place. I had a thick piece of rubber in between it for a while. But then I decided to dent it with a hammer. Hear vibration against it time to time but not that bad
Old 11-24-2015, 06:44 PM
DanielT28's Avatar
DanielT28
Old 11-24-2015, 06:46 PM
DanielT28's Avatar
DanielT28
I found out that I could rotate the d I found out that I could rotate the tailpipe by loosening the clamp on the downpipe. Because it looked to me as if I need to be rotated for clearance and it looks like it worked
Aune163rd
04-19-2011 08:04 AM
idahodisco
09-01-2010 07:03 PM
trencherman
10-04-2008 12:29 PM
crazer42
24
04-06-2008 12:53 PM
wannaburn
03-30-2004 04:40 AM
Quick Reply: Down pipe clearence issues.
