Open rear diff???????
#32
Toby you have a full floater. Luckily ford in this era didn't do that half baked 3/4 ton axle like my dodge has.
Also if not changing ratios and there isn't anything wrong you can prob skip the bearing kit. You would only need the carrier side bearings. Check before buying as some aftermarket carriers take specific special bearings. I have not researched to know if the Detroit does or not.
#33
#34
I feel stupid, so I basically need to pop off a hubcap (yea I don't have fancy wheels) and I should see a hub in the center. Correct. And Aaron, thanks as always, when I get out of work I will check it out.
