open diff.....
Old Nov 27, 2016 | 06:12 PM
anthonym92's Avatar
anthonym92
open diff.....
So my vin and everything says I have an open diff in the rear. But both my tires spin in the snow.......I know on my mustang only one tire spins in the snow being a v6 with an open diff as well......does this mean I better park my truck until I get friction modifier added?
Old Nov 27, 2016 | 06:40 PM
animator's Avatar
animator
Just pop off the cover and look to see if you have a locker or limited slip. If either are present, refill with the appropriate gear lube and don't worry about it.
Old Nov 27, 2016 | 07:04 PM
rla2005's Avatar
rla2005
Spinning both tires with little to no traction does not mean you have a limited slip differential. If the options on the VIN check indicate an open differential then that is most likely what you have.
What is the rear axle code on the door jamb sticker?
Old Nov 27, 2016 | 08:13 PM
Conanski's Avatar
Conanski
You may have some more investigating to do like put the truck somewhere where both tires have vastly different traction and see if both still spin. If they do and your axle code indicates an open diff then it's possible the rear axle has been swapped or a PO installed an aftermarket diff.. lots of possibilities given the age of these trucks now.
finallyo3gt
37
Nov 18, 2015 04:28 PM
Platinum08
Dec 10, 2014 09:39 AM
robertbourque
Apr 17, 2007 03:29 PM
ACM
Feb 21, 2006 09:24 AM
jubrown
1983 - 2012 Ranger & B-Series
Dec 7, 2003 06:50 PM
