50 ford f1 vent window setting tape
Had to repair our vent window handle today. To do so we had to take the glass out, not a bad job. I cleaned it well, painted it, and then used setting tape I picked up from cg ford. It went in fine using soapy water but it's pretty loose, not a tight fit like I expected. What's the best thickness and type of setting tape to use?
If you use urethane to glue the glass in, good luck if you ever break one.
I cleaned it well, painted it, and then used setting (glass) tape I picked up from cg ford. It went in fine using soapy water but it's pretty loose, not a tight fit like I expected. What's the best thickness and type of setting tape to use?
Glass tape adheres vent window glass to the frame, door glass to the window channel, there are different widths.
I hope you get it figured out. The vent frame inside width on my '52 is .360" and the original glass is about .220" - only problem is that my replacement glass measures about .245" so I will need thinner tape than original. I've got a couple different widths to try, and was also told to "slather" it with motor oil when installing. - Bob
mic'd the glass in four places and frame in four places, averaged both, took the difference and halved it, exactly 1/16. The tape from cg is 3/64 which would probably work on new glass is too thin for original glass. Wish me luck on 1/16. After soaking in oil do you wipe it down at all or insert with it dripping?
Jb
Jb
Redgranite_Yooper
05-23-2015 08:51 PM
