Vent Glass Install ?
Old Oct 13, 2008 | 03:03 PM
Ira Brown's Avatar
Ira Brown
I am ready to install the glass in my newly painted vent window frames.
Do I need to purchase rubber window channel ? When I check LMC I can't seem to to find it.
Is there a rubber window channel that is shaped to back up the closing mechanism.
If I go to my local shop and buy window channel won't there be a space behind the stainless bracket to the latch?
Old Oct 13, 2008 | 05:39 PM
Woodsman_30350's Avatar
Woodsman_30350
I took the easy route. Dropped mine off at the glass shop today.
Old Oct 13, 2008 | 08:59 PM
dylan1952's Avatar
dylan1952
You need "setting tape". This is a rubber type tape that you fold length wise and push into channel before glass is installed. Use some window cleaner as a lubricant to get glass to slide. Don't use oil,WD-40 or similar sprays because the oils get trapped and will potentially cause bubbles in edge of glass. I sat frames on a 2x4,installed tape,shot it with windex and used rubber hammer to bump the glass in. Works well, you can find this tape at Mid-fifty,Sac. Vintage Ford maybe even a local glass shop.
Old Oct 13, 2008 | 09:24 PM
Max E's Avatar
Max E
I hope you did order new weatherstripping for the vent and the door glass as well. You'll be sorry if you try to reuse
Max E
Old Oct 13, 2008 | 09:34 PM
bememe's Avatar
bememe
Where are you in Az, Ira? I have just finished one of my doors with new pieces from LMC Truck Parts. The channel you are talking about is the division bar and is several components together in 1 piece. I see no real alternative to buying the new repop piece and they aren't that expensive. I'm in Glendale, if you're anywhere close it would be worth looking at mine.
Old Oct 13, 2008 | 09:59 PM
Ira Brown's Avatar
Ira Brown
Max E
I order everything new. But could not find what I needed for the glass in the frame.
Thanks for the advice.
Old Oct 13, 2008 | 10:00 PM
Ira Brown's Avatar
Ira Brown
Max E
Old Oct 13, 2008 | 10:30 PM
Ira Brown's Avatar
Ira Brown
I have the division bar and components but I did not get a piece of rubber that goes inside the vent frame itself. I have everything but these pieces.
I found the tape mentioned in the post above at mid fifty. I think Iwill give them a call tomorrow.
I am in Chanlder. Thanks for the offer though.
