Vent window glass??
Old Feb 21, 2008 | 09:48 PM
P3aflyer's Avatar
P3aflyer
Question Vent window glass??
Ok, I asked this question before but the thread became so clogged up that no one will get to the point or be able to answer the question.
What do you use to install the vent window glass back into the metal frame with?
THX
Old Feb 21, 2008 | 11:23 PM
bucks77ford's Avatar
bucks77ford
I believe you could use a general purpose double sided acrylic tape from 3M that would bond to glass. NPD sells some glass seal strips made for the window roller chanel and the vent wing, but I'm not sure the brand Name (3M?).
Old Feb 22, 2008 | 10:29 AM
P3aflyer's Avatar
P3aflyer
Thanks,,
I will check into it.. My firts thought was to use the stuff that our door window rollar channels require.. I wasn't sure if someone had already tried it?? The goop tube stuff is a good idea but then again it would be hard to keep the glass centered.
I am having the glass tinted and the frame powder coated after it goes togteher I will take some shots for the gallery.
Regards,
Old Feb 22, 2008 | 06:44 PM
P3aflyer's Avatar
P3aflyer
Ok here is the answer to my own question answered in another thread...
Vent window glass is held in place by,,,,
Glass Tape.,, It can be had at any auto glass shop...
