? on attaching window glass to brackets
The correct way is to use glass setting tape. The door windows are fairly easy, but the vent windows can be a real bear. Take them to a glass shop and have them do it. Well worth the $$.
Once I used window urethane adhesive to hold in some vent glass.......horrible mess and no way to ever get them out again....
Elmo
Short pc. of 2 x 8 needed to accept the large curve of the glass.
Did not use a pc. of wood on t straight side . Pads on quick grip bar clamps will suffice .
Did not cut the corners of the glass setting tape . Once again have 10.6' of tape . It is also listed on upay . Good luck, be patient & carefully squeeze it in . Make sure the inside of your wing window frames are super clean . A little squirt bottle of soap & water will help .
littlecobra1977
11-07-2011 08:54 PM
