Torque converter drain
Thanks all.
Just to confirm the steps
-pull flywheel housing cover
- rotate flywheel using wrench on fan pully
-align converter drain plug and remove plug.
- reinstall plug
-clean up inside of flywheel housing
- reinstall cover
-add 4 quarts dextron atf to pan
-Run engine
-Add anouther 4 quarters
-Run engine
-Top off atf
I read something about adjusting an intermediate band but don't know what that is
- reinstall plug
- reinstall cover
-Run engine
-Run engine
-Top off atf
Rere
Anouther good link, but I am still confussed on oil to use for a pre. 77 c6.
I was all ready to use dex/ merc which now seams wrong after reading post
According to number dummy type f is used for 77 and below. So I need to find some.
https://www.ford-trucks.com/forums/9...uestion-4.html
No, the drain plug is in the converter itself, not in the bell housing.
It's positioned on the front of the converter, facing forward towards the engine. There are usually four holes in the flexplate that give access to the drain plug, regardless of the position that the converter & flexplate were bolted together in.
Here is a link showing the drain plug (pic at bottom of the page)............http://www.fordification.com/forum/v...ic.php?t=26328
R
When I look through all the access hole every one is open all the way to back of bell housing. My access holes are to left of bolts not to the right as shown in pic
Something else I noticed in the pic was the 2 brackets just on side of oil pan.
I do not have these. Where do these connect on engine side
At a radius that is same as flywheel bolts my Torgue converter does not have any material other then where the flywheel bolts attach. Given no material at any access holes there can be no plug at access holes.
In all flywheel holes without bolts, I can see all the way back to the bell housing wall & plugs.
Maybe the torque converter plug is not located along same radius as the flywheel bolts or maybe the plug is just facing down and not torwards the engine. Final option is no plug at all and PO coupled a different C6 to the 429.
Dkrowland81
02-17-2011 08:12 AM
