Torque converter tech?
Old Apr 18, 2007 | 05:50 PM
yh731801's Avatar
yh731801
when the engine is running the converter fills with fluid right? when engine os shut down does the converter drain back into pan ?
Old Apr 18, 2007 | 08:54 PM
jroehl's Avatar
jroehl
It may drain some, but it still contains quite a bit of fluid. To change your tranny fluid fully, you pretty much have to remove the inspection cover and rotate the T/C until the drain plug is at the bottom and drain it.
Jason
