ignition switch
If similar/same as the 65-66 if the key assembly is not installed in the ignition switch correctly then what you are experiencing may be the result. Had similar issue after purchasing the 65, on occasion the key would fall out of the ignition switch, or turn the key off while the engine continued to run. Suggest remove the key assembly, need to place the key in the same position as it was when you removed it.
*Removing:
Insert ignition key, remove key assembly by inserting paper clip, or something similar, to unseat the 'ball' what I will refer to as the 'ball', then rotate the key assembly counter clockwise and the assembly should come out.
*Installing:
insert key in the assembly then rotate key to the counter clock position, may need to use finger to unseat the 'ball' in order to position the key in counter clockwise position, then insert the key assembly turn clockwise.
Suggest take a few minute and look at the concentric cam on the end of the key assembly. Check the inside of the ignition switch and you will find a corresponding slot and notice the concentric cam can only be inserted one way, like can not put a round peg in a square hole.
*Removing:
*Installing:
RBerry9511
02-07-2020 04:31 PM
Obtuse1
17
01-25-2014 12:29 PM
63beater
04-18-2009 08:19 AM
