ignition switch
Old Aug 26, 2015 | 03:45 PM
jlc23's Avatar
jlc23
ignition switch
Replaced my ignition switch and now the accessory lights stay on without key in the acc or on position ? No other changes , just replaced the switch after the original fell apart.
any thoughts?
Thanks
Jerry
Old Aug 27, 2015 | 11:03 AM
sseebart's Avatar
sseebart
any thoughts?
Thanks
Jerry
What year truck is this? My 62 doesn't have anything I would consider an accessory light.
~Steve
Old Aug 27, 2015 | 11:21 AM
daveengelson's Avatar
daveengelson
If similar/same as the 65-66 if the key assembly is not installed in the ignition switch correctly then what you are experiencing may be the result. Had similar issue after purchasing the 65, on occasion the key would fall out of the ignition switch, or turn the key off while the engine continued to run. Suggest remove the key assembly, need to place the key in the same position as it was when you removed it.
*Removing:
Insert ignition key, remove key assembly by inserting paper clip, or something similar, to unseat the 'ball' what I will refer to as the 'ball', then rotate the key assembly counter clockwise and the assembly should come out.
*Installing:
insert key in the assembly then rotate key to the counter clock position, may need to use finger to unseat the 'ball' in order to position the key in counter clockwise position, then insert the key assembly turn clockwise.
Suggest take a few minute and look at the concentric cam on the end of the key assembly. Check the inside of the ignition switch and you will find a corresponding slot and notice the concentric cam can only be inserted one way, like can not put a round peg in a square hole.
Old Aug 27, 2015 | 12:30 PM
jlc23's Avatar
jlc23
The truck is a 66. All dash - oil,alt , are on whether or not the key assembly is installed. Seems like a short of some variety.
Old Aug 27, 2015 | 04:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ignition switch is the same: 1961/66 F100/1100 / 1961/64 Galaxie / 1965/66 Mustang / 1966 Bronco and etc.
Old Aug 28, 2015 | 05:31 AM
User 71024's Avatar
User 71024
If you are talking about the dash lights, they are not run threw the ignition switch, they are powered directly from the battery to the head light switch. Has nothing to do with the ignition.
RBerry9511
Feb 7, 2020 04:31 PM
Obtuse1
17
Jan 25, 2014 12:29 PM
63beater
Apr 18, 2009 08:19 AM
93Sunplex
Feb 27, 2007 06:17 PM
raineytx
Nov 22, 2005 11:54 AM
