Transfer case compatibility
My transfer case in my 94 f350 just started dumping a lot of aluminum shaving into the oil, it has 282k miles on it. Just changed oil 20k ago.
I found a transfer case from a 93 f150, manual shift and slip yoke output like mine.
Will it work?
Mine has a pto option but does that matter?
What is with the different metals, mine is mag and aluminum case halves.
I'm rebuilding before I do the swap so I don't have a long downtime waiting for parts.
Will it work?
Which TC is in the truck now, and which one is in the 1/2 ton? I did kind of the same thing. I pulled a TC out of a 1980 3/4 ton Borg Warner 4 spd and swapped it over to my 97 F350 with the ZF S5-42. (My 1980 was not factory by any means though. Had a 460 down in her, so the drive train was probably from a different truck as well. I believe it was the NP208 that it had in it.
Update: I drove another thousand miles and dumped the transfer fluid, still have a lot of glitter( no 4x4 action).
In the local junkyards I found a transfer case with 47k miles. It's out of a 95 f250.
Is the front yoke swap just an unbolt and swap ordeal?
Besides losing the PTO option, are there any drawbacks?
duct tape F-150
22
05-05-2013 08:15 PM
bowman91centurion
04-29-2013 09:52 AM
Eddiec1564
05-04-2007 07:27 PM
