Fuel pump question
Fuel pump question
Maybe sounds silly but.....I don't drive my 2000 7.3 everyday. She only has 93,000 on her. Here is my question .. I think I remember the fuel pump under the cab used to run for a couple seconds when I turned the key to on. I noticed that I don't hear the pump any longer. The truck seems to take more revolutions now to start, used to start right up. But it does start and run ok.
If it runs the pump has to be ok, is there a separate circuit for power when key is turned to ON position maybe?
You say you used to hear it. I would suggest you use a DVOM w/Low Amp Clamp. If its using more than say 12+ AMPS, replace it. If it starts an maintains 8-11 smooth, don't sweat it.
That 40 mph comment got me, too, Rich.
Perhaps in the context of his recommendations for checking the amperage on the pump, he might be implying that the pump won't put out enough fuel to go more than about 40 mph if there is for some reason a reduced amperage driving the pump's internal pistons (internal short inside the pump motor, corroded/loose wire connection, weak/dying battery, etc.).
just had this issue. cannot believe the truck even ran. pressure gauge was showing ~4psi at most.
pump was ~6 months old. took it back to oh-rye-lees and got a new one. back to a solid 72psi now.
The OP wrote referring to the Fuel Pump:
"If it runs the pump has to be ok, is there a separate circuit for power when key is turned to ON position maybe? "
My response was:
"Often they will start but not run over 40 mph or so" This statement was intended to inform the poster that: "If it runs the pump has to be ok" in NOT a method of accurate troubleshooting; "As Often they will start but not run over 40 mph or so"
Tom
While this isn't a direct answer to the question:
I did a lot of homework on fuel pumps for the 7.3L when I was powering up. After looking at every pump available on the market that allegedly fits the 7.3L diesel, the OEM is the best performer and most reliable - unless you install fire hoses for injectors. If I had that situation, I'd engineer a dual-OEM system.
I bought my OEM from Riffraff Diesel to get a better price than from the stealership.
I admire you Rich, but on fuel pumps, you and I disagree. I am OK with that. I trust you are too.
StevenHolt
09-26-2004 08:54 AM
