P-1280
Old Aug 8, 2015 | 07:16 PM
Edogsf350's Avatar
Edogsf350
P-1280
Hi all needing some help for a friend. I normally hang out in the 6.0 section so bare with me. I attached a code down load from AE and as you can see he has a active P-1280 code. So far the sensor and pig tail has been replaced. I will watch the ICP Pid and the voltage will be ok the drop down to 0 then come back. I looking for some suggestions on what to check??
truck info 03 7.3L 240xxx miles
File Type: pdf
Old Aug 9, 2015 | 02:05 AM
Edogsf350's Avatar
Edogsf350
bump to the top
Old Aug 9, 2015 | 03:56 AM
white Buffalo's Avatar
white Buffalo
Is the check engine light on as well? Also, did you clear the trouble codes after replacing the sensor?
Strange that the MAP reading is 25 with the Key On Engine Off. It should be reading the same as the Baro and EBP sensors at KOEO.......
Since you have AE, I would data log a 20-30 second WOT run from 50-80 mph. Data log, ICP, ICP duty cycle, MPH, Baro pressure, MAP, EBP, Fuel Inj Pulse Width and RPM's. Then post up a pic of the graph so we can see a snapshot of the run.
Old Aug 9, 2015 | 08:00 AM
Tugly's Avatar
Tugly
The PDF said the MIL was on, and the 25 is in. hg.
Yeah... log those PIDs, but an automatically generated graph may not show us anything if the maxes are set too high.
Old Aug 9, 2015 | 07:29 PM
Edogsf350's Avatar
Edogsf350
ok I will get this data logged and post back but just be patient because me and my buddy have oposite scheduels. Ths pdf was taken after the codes were cleared and was at a idle in my drive way. As you can see the P1000 code from being cleared and not driven
tx.fire.sign
Aug 13, 2018 05:15 PM
Quigles4
Jan 27, 2013 12:32 PM
Holtian
13
Jul 15, 2011 04:19 PM
richmone73
Bronco II
Jan 8, 2011 11:31 PM
newtattoobob1
1983 - 2012 Ranger & B-Series
Jun 19, 2004 07:59 PM
