Crap truck is dead in the Walgreens parking lot.
Old 06-29-2015, 07:39 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
Truck wont turn over even when you jump the sylanode. Checked fuese had one blown under hood and replaced still no crank. Battery is brand new but jumped it any way. it does not even feel like the starter is engaging. Batter y and sylonode is getting 12 volts. Any thoughts? Need help bad. I hope I gave enough info.
Thanks!!
Old 06-29-2015, 07:54 PM
02GrayPowerStroke
Is there a main bad *** fuse some where?
Old 06-29-2015, 09:47 PM
02GrayPowerStroke
Bad starter??? I jumped from the + battery to the starter and it did not do anything.
Old 06-30-2015, 05:00 AM
rmccbride's Avatar
rmccbride
rmccbride is offline
It's probably the little metal strap that ties the +pole on the starter to the starter engaging solenoid has rusted through.
You can try jumping between the big pole and little pole on the starter while some one turns the key.
Old 06-30-2015, 09:25 AM
auskip07's Avatar
auskip07
auskip07 is offline
Could be worse, dead on the side of the road. It is 16 years old
Old 07-01-2015, 12:37 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
This is a normal issue for many after the truck is aged.
The starter brushes wear down and hang up in there holders.
Replace the starter and the start solenoid, clean the battery posts and terminals.
Nice to condemn the truck instead of repairing it.
Good luck.
Old 07-01-2015, 09:07 PM
02GrayPowerStroke
Tried this and no go. Starting to think its the starter. What do you think? Any other ideas?
Old 07-02-2015, 08:34 AM
auskip07's Avatar
auskip07
auskip07 is offline
bang on it with a hammer. should free it up
Old 07-02-2015, 09:34 AM
Don Naslund's Avatar
Don Naslund
Don Naslund is offline
If the battery is good, I would confirm that the cable ends are clean and tight, especially the ground. If you have the positive going directly to the solenoid then you do not need to worry about any other part of the wiring of the truck. Jumping the solenoid bypasses everything. I would take a jumper cable directly to the starter and positive post of the battery. If the starter doesn't turn, pull the starter. Yes, it could be stuck but taking the bolts out will free it up and you will hear it go clunk when you try to take it out. If it clunks, put it back in and try it again.
Old 07-04-2015, 02:04 PM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
try this...just for grins....
remove the serpentine belt...then try restarting.
It maybe that the A/C compressor is locked up.
Or...maybe your head gasket took a dump and you have a cylinder er 2 full of cooolant
Old 07-11-2015, 10:17 PM
02GrayPowerStroke
It was the starter, thanks for the help.
49f3dls
03-06-2016 01:59 PM
MackGuy
01-15-2013 06:44 AM
bigdogchris
1978 - 1996 Big Bronco
04-28-2012 07:21 PM
17fordguy
13
10-10-2007 04:16 PM
Marc150
13
12-14-2004 04:37 PM
Quick Reply: Crap truck is dead in the Walgreens parking lot.
