Reversing Aid Module
on
So has anyone had problems with their Reversing Aid Module..(radar). Mine quit working and just gives an error message to "Check Reversing Park Aid Module" when I 1st start the engine.. I have checked the 5 amp fuse.. it is good.. Taking it to the dealer is a pain.. but I might have to.. Only has 3500 miles on the clock..
Please update if you could on whether this fixed your problem. I just got a 2011 and this same error message is the only fault I can find with the truck. Same error message, and no beeps while reversing up to something. A part number/location on that module would be appreciated. I've only had it for five days but sooner or later my wife is going to be driving this CC LB and I'd really like to fix this before then!
on
Yes, it fixed the problem. Sorry, can't give you P/N. It appeared to be located below the steering column area, but can't tell you exactly where.. I watch the Ford Tech work on it from a distance. The Parts Counter guy could give you the P/N.. It is the "sound device" that caused the lack of the beeping..
If the sensors all look good, do a check to see if they're alive:
Safety First: Set the Parking Brake, and block the rear wheels so the truck doesn't roll over you.
Turn the key to "On" to activate the electronics, but don't start it. Shift it into "Reverse." Then close the doors so you don't hear the stupid door chime.
Go to back of truck. (Reverse Lights should be on.) From the side of the bumper, lean down so you can get your head near each sensor. As your face (hand, or other body part) goes in front of a (working) sensor, you should be able to hear a faint click as it detects you. The one (or more) that doesn't click is/are defective and need to be replaced. (If none of them click, then they're most likely not getting power and you probably have Clintbonnie's issue)
Here's the part # for a replacement sensor.
REVERSE SENSOR for 2011 Ford F-250 Super Duty|3F2Z-15K859-BA
Part # for the Reverse speaker
SPEAKER for 2011 Ford F-250 Super Duty|4L1Z-15K864-A
Part # for Reverse Sensor Control Module
MODULE for 2011 Ford F-250 Super Duty|BC3Z-15K866-C
(these parts are the same for F-250 thru F450)
On edit: Did you get any sort of guarantee with your truck?
