truck died while driving
Old 04-25-2015, 10:44 AM
jhubb's Avatar
jhubb
jhubb is offline
I have a 2007 explorer that died while i was driving. We have changed the battery, alternator, spark plugs, fuel filter, and have checked the fuel pump, starter, throttle body. The truck cranks but wont kick over. I am out of ideas. Any suggestions/ideas?
Old 04-25-2015, 11:45 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is online now
Phantom of the Phorum
You didn't say anything about checking for error codes. Have you done that?
Also, welcome to FTE.
Old 04-25-2015, 11:55 AM
jhubb's Avatar
jhubb
jhubb is offline
thank you. no, my truck is in my driveway and wont start at all and i dont have anything to check for codes.
Old 04-25-2015, 01:43 PM
AzPete's Avatar
AzPete
AzPete is offline
Have you tried a slight big of starting fluid.....just a small spray to see if it tries to fire.....could identify fuel vs spark problem. Sarting fluid us not recommended for these engines but I have used a small amount to check for fuel flow issues....
Old 05-23-2015, 06:30 PM
Rbborek's Avatar
Rbborek
Rbborek is offline
This may sound obvious, but did you change the fuel itself ? We had a similar issue once and the fuel went bad and it would not start. It was a pain but it helped.
Renee
Old 05-25-2015, 10:25 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Five things are required for an engine to run- Fuel, air, spark, compression and timing. Take away any one of those and it will not run. Beyond replacing parts, what have you done for testing? Does it have spark, fuel, good airflow, and compression? Did anything unusual happen when it stopped running? Does it sound normal when cranking over?
Old 05-27-2015, 11:36 PM
weross67's Avatar
weross67
weross67 is offline
If it is not firing check the Crank Shaft Position Sensor.
bigmike1161
13
06-20-2017 11:05 AM
ccmeigs
1983 - 2012 Ranger & B-Series
13
10-27-2010 06:52 PM
explorerchamp50
04-15-2010 03:34 PM
bigdogpc
19
07-17-2006 09:35 AM
bdkoz1
11-15-2001 08:09 PM
Quick Reply: truck died while driving
